Hi,
So I have been trying to get my game (Overwatch) to use more than its currently taking. I have 8GB of RAM and it seems to only use around 1.3GB, similar story with VRam on my graphics card, I have 3GB but it only uses around 900MB. Is there anything I can do to give the game more power so to speak?
Windows 10, 64-bit.
https://linustechtips.com/topic/652448-overwatch-using-little-resources/
The only way to increase the games usage of vram is to up the graphics but if it is at max settings then it's where it should be.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
I got a 8GB GTX 1080 and overwatch uses 900-1050 of it...
Getting my GTX 1070 and its probably going to do the same, I wish I could dedicate it more sigh.. I mean years ago Call of Duty 4 was pushing 1GB Vram and using 4GB Ram.
I'm confused. Why exactly do you want it to use more?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
