I've got the ASRock Z97m Pro4 motherboard currently, with 4 fans in my case;
2 on the CPU cooler, connected to CPU fan 1 and 2
2 on the case, connected to chasis fan 1 and 2
CPU fans 1 and 2 can be controlled via the UEFI and programs on my PC, and so can chassis fan 2. However for some reason, chassis fan 1 can't be controlled no matter what I try, and it's running at ~75% so it's annoyingly loud...
Anyone know of any solutions? I do own a fan controller, but it's cheap and tacky, and makes the case look a mess with the cables stretching out everywhere
Thanks
Nathan
https://linustechtips.com/topic/652351-cant-control-chassis-fan/
Thanks
Nathan
Is it plugged into a three-pin connector? If it is those cannot be controlled like the four-pin ones, which are known as PWM.
https://linustechtips.com/topic/652351-cant-control-chassis-fan/#findComment-8378775
Yeah its a three pin. I understand what you're saying, but all my other fans (apart from 1 cpu fan) are all 3 pin and can be controlled through the UEFI or programs, I guess it just alters the voltage. That's why I don't understand why this one fan wont work
https://linustechtips.com/topic/652351-cant-control-chassis-fan/#findComment-8379051
Ah, well in that case I don't know then. Sorry!
https://linustechtips.com/topic/652351-cant-control-chassis-fan/#findComment-8379126
What fans do you have and which headers are each fan plugged into?
https://linustechtips.com/topic/652351-cant-control-chassis-fan/#findComment-8380189
Do you have a low noise extension? They can really help with the noise.
Have you tried swapping the fans to see if it is a motherboard issue or a fan issue?
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/652351-cant-control-chassis-fan/#findComment-8380670
