My budget only for RIG : 3000-3500 euro
Was looking for :
CPU: i7 6850k
CPU Water Cooling: Still looking for one
GPU: Asus Strix GTX 1080 x2 (SLI)
dont know what sli cable should i buy
Mobo: Dont know what to get due the unlimited options.
Ram: 32Gb DDR4 3000Mhz CL15 Corsair Dominator Platinum quad channel
SSD: PCIe SSD Samsung 950 - 512Gb
Source: Corsair RM1000x
Case: thinking of Evolv ATX but.. i need a good airflow and nice design (inside and outside)
I need some suggestions please. Haaalp !
The rig will be bought in two weeks.
https://linustechtips.com/topic/651706-future-ultimate-rig-need-help/
For a water cooler go with the corsair H110 or if that's too expensive the H50 is fine too.
Here is a list of great motherboards that should work with your build.
http://pcpartpicker.com/products/motherboard/#L=4&l=2,3&m=8&s=28&sort=a8&page=1&f=2&u=1&N=8,16&E=1,3
Was looking for :
CPU: i7 6850k
Don't go with the asus 1080s. While good by themselves, not good together. Open air coolers have trouble together. Bower style reference card do much better in sli. Get Founders editions. Also what are you going to be doing with this?!!! This is op!
