So I bought a white cablemod LED strip today to give my PC some much deserved bling. However I'm a bit confused on how to plug it in. It has two sides where a sata power cable might go. The one that says Sata power on it won't fit my sata power cable, however the one labeled M Sata does, so I plugged that in. I then ran the little 4 pin cable from the power module to the strip itself and plugged that in. However the strip also came with a little cable that's 4-pin male to 4-pin male again. What is this for? Am I missing something? Being my paranoid self I want to make sure before I power on the system.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/651417-am-i-led-ing-correctly/
4 minutes ago, thekeemo said:
Them double posts though...
It's not a widebeam, just a single color with no remote/control of any kind. But I think this confirms I did it right. I think I'll power on, don't see anything bad happening.
https://linustechtips.com/topic/651417-am-i-led-ing-correctly/#findComment-8369547
They are LEDs so they will only allow power through the right way anyway
https://linustechtips.com/topic/651417-am-i-led-ing-correctly/#findComment-8369550
49 minutes ago, Bleedingyamato said:
Certainly worth considering.  Can they be set to purple and stay that way unless changed by the user?
They sure can - will be no problem at all - here is a video introducing our LED Strips:
https://www.youtube.com/watch?v=K-UyK_l0jpA
https://linustechtips.com/topic/651417-am-i-led-ing-correctly/#findComment-8388694
Thank you for showing that to me.  I'll definitely keep that in mind.  It certainly looks better than the crap LED strips that came in my desktop.  ?
https://linustechtips.com/topic/651417-am-i-led-ing-correctly/#findComment-8389128
