After purchasing a 144hz monitor I switched from using a hdmi cable plugged directly into my GPU, to using a DVI cable plugged into my motherboard (To use the 144hz). Now after moving my PC and plugging it all back in I turn on the monitor and it says no cable connected even though it is clearly plugged in correctly. The HDMi works when plugged into the GPU and the DVI shows up when the GPU is not plugged in, however when the GPU is in and I try to use the dvi it doesn't show up anymore. Thanks for the help in advance.
https://linustechtips.com/topic/651280-dvi-no-longer-working-please-help/
Go into the BIOS, there is usually an option for configuring display adapters which disables the motherboard graphics when a GPU is connected, it sounds like that has been toggled back on.
try using an hdmi to dvi connector like this: http://www.ebay.com/itm/DVI-D-24-1-25-Pin-Male-To-HDMI-Female-Adapter-Connector-Gold-Plated-Stylish-/201468572673?hash=item2ee8767401:g:1mIAAOSwZVhWSttA
connect it with the hdmi cable directly to the graphic card... or use a display port cable, provided your monitor is compatible...
|| CPU Intel i5 4690k @ 4.00Ghz || MB Gigabyte Z97X-UD3H, REV 1.0 || RAM 8GB (2x4GB) Gskill Sniper 1600Mhz CL9 DDR3 || GPU Gigabyte Nvidia GTX 660 OC 2GB (waiting for AIB versions of polaris and gtx1060…) || Case NOX Coolbay VX Zero || Storage 1 x 128gb kingston ssd v300 1 x 2TB WD Green 1 x 1TB WD Black 1 x 320GB WD 2.5" Internal samsung DVD Recorder 5.25" (24x) || PSU Aerocool strike-x 800w modular 80 plus silver || Display(s) Philips 24" full hd Monitor or LG 49UB830V-ZG 4k 3D 49"|| Cooling Seidon 120v plus for cpu + coolermaster jetflo x1 back outtake; coolermaster jetflo x2 top - outtake + XIGMATEK CLF-F1251 x2 front intake + nox coolfan 120mm white intake bottom || Keyboard Microsoft MediaKeyboard 3000 and Cyber Snipa Flexiglow Keyboard || Mouse Ozone 5k laser gaming mouse || Sound Philips Stereo with around 75W rms for extremely loud sound lol; ozone rage st and AKG K44 HeadPhones (which i usually use for guitar, and not for gaming  lol) || Operating System Windows 10 pro x64 ||
Like @Glenwing said the motherboard connection is probably turned off because you have a GPU installed. So either try his suggestion or if your GPU doesn't have a DVI connector, get a DP cable (if your monitor has DP).
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
I tried looking for something like this but didnt have any look, I will try again.
If I used that adapter would I get the 144hz + My monitor doesnt support display port
not absolutly sure but it will be a cheap test... only 2 to 5 bucks for the adapter... you can also try a display port to dvi conector... also cheap
The only thing I can find in the integrated graphics place are two tings: PEG and IGD I dont know what they are?
HDMI 2.0 can do 120 Hz, though you need a compatible monitor and gpu. You'd also need a certain type of HDMI cable IIRC. I think you're best bet is to try a DP to DVI cable/converter that supports 120+ Hz.
This is so annyoing because it was wokring before I moved my PC.
I think I may have misunderstood the situation a little bit then. If the same setup worked before then all I can think of is what @Glenwing said unfortunately :/
So do you think everything is still working fine in terms of the gpu and mobo?
15 minutes ago, max97865 said:
I have the graphics set as PEG in the BIOS which I think means something to do with PCI, so the graphics card.
Yeah that's the PCI-E slot. What are the other options there? Is there something like "PEG/IGD" (as a combo, not separate) in the options? That should enable both PCI and the on-board graphics I think.
Everything should be fine.
The only two options are PEG and IGD and it is set as PEG but the DVI still does not work
Setting it to IGD would enable the DVI on the motherboard, but disable the PCIe slot.
Yeah but then I wouldn't be able to run games as easy, anyway thanks for the help man
Yes. Just a random thought, but maybe you can refund the monitor and get a different one with DP? Or just keep it if you'll upgrade/change to a card with DVI in the future.
