Need some help guys
Go to solution Solved by ShadowCaptain,
On 27/08/2016 at 0:36 AM, David-McLean said:
I was wondering if there was an option to adjust the f-stop (Aperture) on the "Lumix G7" whilst on video mode.
Yep there is, but I dont have the camera here to tell you how
normally one of the dials on the camera
https://linustechtips.com/topic/649605-need-some-help-guys/#findComment-8377697
  • 2 weeks later...
2 minutes ago, David-McLean said:
Thanks for the help
make sure you are in manual video mode too :D
https://linustechtips.com/topic/649605-need-some-help-guys/#findComment-8534641
