Need help on planning
Hi all, this is my first post in this forum, and i would like to ask for help on my planning.
I currently game on console, but found 2 old PCs (1 with celeron and another with a Pentium4 at 3.4)
Long story short I took apart both PCs and mixed the best components for both, so I ended with the Pentium4 at 3.2ghz, 2 gb of DDR2 RAM, a 250W PSU, and a GeForce 610 GPU.
This PC runs good, having the dated components, I can even run MW2 and Halo2 with decent settings.
Now, the real question is...  (Im in mexico, so ill put prices in MXN   1 USD = 19MXN approx)
Im planning to build a new PC for gaming and ocassional work as programmer, with a tight budget  (10,000MXN aprox), so i was planning on getting:
G1.sniper.a88x motherboard for 1926.00 MXN
SAPPHIRE Radeon NITRO R7 370 4GB GDDR5  for 3272.00 MXN
AMD A10-7890K 4.1 GHz with wraith coller included for 2956.00 MXN
Decent EAGLE WARRIOR Robot X case  for 900 MXN
8GB of Kingston HyperX Fury 1866Mhz for 715 MXN
EVGA 600W 80 plus silver for 1172.00 MXN
SSD ADATA Premier SP550 240GB Sata3  for 1242MXN
HDD i will use the WD 500GB that i have running in the Pentium 4 machine and expand later on.
Now all this adds up to 11283MXN, a little off budget due to the R7 370, but what I really wnat to ask is , shall I go for this build, which i will be completing in the next 2 or 3 months, or, buy just the r7 370, use it in my old PC build (I know it will get bottlenecked) and wait for ZEN to be released???
I really love this forum, digging around the experiences with non techies when bored at work LOL!
I appreciate you guys taking a look in advance!  (Remember I´m mexican and English is my second language, so be patient)
https://linustechtips.com/topic/649367-need-help-on-planning/
How much is a GTX 950 instead?
You're paying too much for the A10-7890K (I would know, I live in mexico). Instead try to put together a build with i3-6100, B150 motherboard, DDR4. it will be better
I would not buy anything from Eagle Warrior because they make literal hazards for PSUs (they're a brand of Pixxo last I checked)
Here's a list all from amazon.com.mx
https://www.amazon.com.mx/PACIFIC-BX80662I36100-Procesador-Intel-I3-6100/dp/B015VPX2EO/ref=sr_1_1?ie=UTF8&qid=1472226913&sr=8-1&keywords=i3+6100
i3 6100 2022MXN
https://www.amazon.com.mx/Kingston-2133MHz-Non-ECC-Desktop-HX421C14FBK2/dp/B00TY6A1P0/ref=sr_1_1?ie=UTF8&qid=1472226924&sr=8-1&keywords=ddr4+2133+2x4gb
8GB DDR4 HyperX 742MXN
https://www.amazon.com.mx/Gigabyte-placas-Micro-DDR4-GA-B150M-D3H/dp/B016OQL3BS/ref=sr_1_10?ie=UTF8&qid=1472226943&sr=8-10&keywords=b150
Gigabyte B10M-D3H 1747MXN
https://www.amazon.com.mx/SK-Hynix-Memory-Internal-HFS250G32TND-N1A2A/dp/B01H5KW8VG/ref=sr_1_3?ie=UTF8&qid=1472226977&sr=8-3&keywords=sl308
SK Hynix SSD 1410MXN
https://www.amazon.com.mx/Corsair-CC-9011050-WW-Gabinete-Spec-01-Fuente/dp/B00I6BJATW/ref=sr_1_1?ie=UTF8&qid=1472227012&sr=8-1&keywords=corsair+spec+01
Corsair Case 925MXN
https://www.amazon.com.mx/CORSAIR-CX450M-BRONZE-Haswell-Modular/dp/B01B72VXE6/ref=sr_1_1?ie=UTF8&qid=1472227032&sr=8-1&keywords=cx450m
Corsair CXM PSU (pretty great) 928MXN
https://www.amazon.com.mx/XFX-RX-460P4SFG5-AMD-Tarjeta-gráfica/dp/B01JGQUIU0/ref=sr_1_2?ie=UTF8&qid=1472227041&sr=8-2&keywords=rx+460
XFX RX 460 3027MXN
Adds up to 9873MXN and is much better in every way :)
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/649367-need-help-on-planning/#findComment-8350147
I would not get an APU if you are planning on gaming, and buying a graphics card.  Buy either FX 6 core, or i3-i5 Intel, or try and wait for ZEN to come out, so it tanks the market on older AMD tech.
Comp:  i5-6500, Hyper d92,  Z170 Asrock Pro4s, Crucial Ballistix 16gb DDR4 2400, CS1311 SSD, EVGA 600b, GTX 1060 MSI Gaming 6gb, Lancool K62 case
https://linustechtips.com/topic/649367-need-help-on-planning/#findComment-8350150
i3 6100 2022MXN
Corsair Case 925MXN
XFX RX 460 3027MXN
Didnt think about buying at amazon, im checking http://www.digitalife.com.mx/ for this, as i have bought in that store before, prices are not that bad and its really trustworthy.
But I´ll take a look on the parts you picked and see if I can squeeze in an i5.
Thanks!
https://linustechtips.com/topic/649367-need-help-on-planning/#findComment-8350170
Thanks!
I think an i5 is doable for you :)
I'll check out Digitalife and add it to my list of retailers. If you see a better price on the same model there, take it (keep in mind Amazon does free shipping on big buys, check that out too)
Computer Specs:
https://linustechtips.com/topic/649367-need-help-on-planning/#findComment-8350187
In digitalife ASUS GeForce GTX 950 2GB is 3,411MXN
http://www.digitalife.com.mx/producto/19221/tarjeta-de-video-asus-geforce-gtx-950-2gb-gddr5-pci-express-sli-strix-gtx950-dc2oc-2gd5-gaming
https://linustechtips.com/topic/649367-need-help-on-planning/#findComment-8350242
29 minutes ago, chato_raziel said:
I think the XFX RX 460 is better at 3000
If a 950 is less than that, maybe
Computer Specs:
https://linustechtips.com/topic/649367-need-help-on-planning/#findComment-8350386
https://linustechtips.com/topic/649367-need-help-on-planning/#findComment-8350634
