Okay so... I searched around and created a beast of a PC! But now I need to cut costs (again!)... I'm trying to maintain the quality of the build without going too much over 1200 pounds... Any advice?
Here is is my current build! I need to cut the cost: http://uk.pcpartpicker.com/user/bobbygee69/saved/VZwrHx
i also need a keyboard but can't find a good keyboard that can fit in my budget
https://linustechtips.com/topic/649304-help/
Maybe buy a cheaper graphics card (RX 470)?
Also, don't add more fans, the H440 has enough...
And you can buy a cheaper mouse and headset....
(You can use this mouse temporarily...)
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/649304-help/#findComment-8349513
