okay guys so i bought a msi ge70ond laptop for my son for highschool and i cant get it to connect to my home wifi i know its not the wifi card because i can hotspot it to my phone and it will use other open wifi i also know that my modem is also fine because my paytv and xbox one are both connected wirelessely to it and the and the killer e2200 ethernet works fine . So im thinking it must be a configuration thing, i had a bit of a play around in the config of the modem and the wifi card but still cant get it to work by the way the wifi card is a intel centrino wireless-n 135 and the modem is a technicolor tg799vac. I would appreciate any help u guys can offer TIA
https://linustechtips.com/topic/649059-wifi-trouble/
When you say you can't get it to connect to the home WiFi, do you mean not being able to successfully connect to the WLAN or just not being able to connect to the internet via WiFi?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/649059-wifi-trouble/#findComment-8347335
