i have a pretty old pc monitor :) display (1024 x 768)
Anyways, let get right into the QUESTION....
Im trying to scratch 4:3 i did with the Intel control panel when i was using my integrated IGPU while i was waiting for my GPU to come in sadly i cant do with the nvidia control panel it wont let me scale it like Intel would let me scale it. *COUGH* CSGO :P
Is there a program out there that lets me do it my self, let me adjust my monitor to how i want to do it ?
https://linustechtips.com/topic/648974-how-to-scratch-resolution/
What do you mean "scratch"?
NVIDIA control panel should have options to scale it however you want.
11 minutes ago, callofjustices said:
If your monitor is already 4:3, then a 4:3 resolution won't stretch on it, it will fit perfectly. You can only run 4:3 resolutions stretched if you have a monitor that is wider than 4:3, otherwise there is no extra space to stretch into.
But, if you want to stretch then you would select Full-screen from that menu. But like I said, it won't do anything if your monitor is a 4:3 ratio already.
I done with the Intel  one i had black bars on top and bottom
Hmm try setting a custom resolution in the NVIDIA control panel, something like 800×600, and run that with the Full-screen scaling option selected.
Oky so i did that with 800x600 with no scaling this time and i got black bars small res ?!?! whats a perfect res for this :D
