I'm doing my first custom water cooling system, but I cannot find a LGA 1151 water block. I found just about every other block for about $40, can someone please recommend a cheap water block and where to buy it from?
Also being my first time, maybe a little advice too. I learned some basic knowledge about water cooling as far as performance and what parts I need, but have no idea about flow, or what order the parts need to be in.
Thanks, looking forward to hear back soon.
https://linustechtips.com/topic/648558-need-a-little-help/
Any LGA1150 waterblock will fit it.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/648558-need-a-little-help/#findComment-8341784
1 minute ago, TylerHarrell64 said:
Thanks, so anything LGA 115_ will work?
yep
PSU Tier List | CoC
https://linustechtips.com/topic/648558-need-a-little-help/#findComment-8341799
I dont know about that. Maybe a LGA 1151 would work on a LGA 1150.
No no you are right, a LGA 1150 waterblock would work on a LGA 1150
https://linustechtips.com/topic/648558-need-a-little-help/#findComment-8341817
Intel has used the same mounting setup for quite a long time now.
PSU Tier List | CoC
https://linustechtips.com/topic/648558-need-a-little-help/#findComment-8341822
I would suggest if your just starting out to get one of the EKWB kits like the P360 if your doing a full loop with a CPU and GPU with overclocking, they're a great base to build off of for the future.
-Moved to Liquid and Exotic Cooling-
https://linustechtips.com/topic/648558-need-a-little-help/#findComment-8341842
