11 minutes ago, suzuya68 said:
I'm looking to build my first desktop soon and I wanted to share the parts I'm planning on using to see if they're any good. I want it to be around $500-$550 Canadian (not including operating system). https://ca.pcpartpicker.com/user/suzuya68/saved/#view=v4CmGX
Not that SSD. What use case?
- The RX 460 is similar performing and much cheaper
- V300 SSDs are terrible, gave you a different one. Upgraded the capacity while we're at it.
- You're much better off with a branded PSU and a separate case. I don't trust bundles unless the model of the PSU is advertised upfront
- Athlon 845 is the same but consumes less power. I don't recommend OCing on a cheap FM2 motherboard regardless of the CPU model, so the locked multiplier is a non-issue.
CPU: AMD Athlon X4 845 3.5GHz Quad-Core Processor  ($79.99 @ NCIX)
Motherboard: ASRock FM2A68M-DG3+ Micro ATX FM2+ Motherboard  ($59.99 @ Newegg Canada)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($36.43 @ Amazon Canada)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($74.98 @ DirectCanada)
Video Card: PowerColor Radeon RX 460 2GB Red Dragon Video Card  ($149.99 @ Newegg Canada)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($39.99 @ Newegg Canada)
Power Supply: EVGA 450W 80+ Bronze Certified ATX Power Supply  ($44.75 @ DirectCanada)
Total: $486.12
Generated by PCPartPicker 2016-08-24 17:43 EDT-0400
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
If you want to OC the CPU
CPU: AMD Athlon X4 880K 4.0GHz Quad-Core Processor  ($118.98 @ DirectCanada)
Motherboard: ASRock FM2A88X PRO3+ ATX FM2+ Motherboard  ($94.50 @ Vuugo)
Case: Rosewill Blackbone ATX Mid Tower Case  ($39.99 @ Newegg Canada)
Total: $559.62
Generated by PCPartPicker 2016-08-24 17:46 EDT-0400
Computer Specs:
Total: $559.62
That one looks good, but I would add a HDD for storage, SSD for software.
As per OP's request. 240GB is plenty for someone who doesn't have a huge Steam Library or a bunch of video series
Computer Specs:
