I have a AMD fx 8320, i ran a overclock of about 4200mhz and it has always run stable my cpu is water cooled but recently games have not been running and have just crashed and my whole computer crashes as a result. when i go into the motherboard bios it says what i think is my cpu is not getting enough volts, its says cpu (voltage 3.3) and beside in red it show around 2.9 is this the cause of my computer crashing when i launch a game if so how can i fix it.
https://linustechtips.com/topic/647469-games-not-running/
Backup your pc, reinstall everything, then retry your overclock. (Also you might want to consider reapplying your thermal paste)
^Last resort
CPU: i7 6800k @ 4.1ghz | Motherboard: Asus Rampage V Edition 10 | RAM: 64 GB 2400Mhz DDR4 Corsair Dominator Platinum | GPU: GTX 2080 ti Zotac AMP | CASE: Corsair 780T | Storage: 2TB Samsung 970 Evo, 512GB Samsung 950 Pro m.2 Nvme SSD, Samsung 950 Pro 1TB SSD, Seagate 7200rpm 1TB HDD, Seagate 5TB external HDD | PSU: EVGA 850watt G2 | Displays (3): Samsung Odyssey G70 32 inch 1440p 240hz Monitor 1ms rt, LG 32MA68HY-P 32-Inch IPS Monitor, LG 43UD79-B 43" 16:9 4K IPS Monitor | CPU Cooler: Corsair H115i | Keyboard: Razer Huntsman Mini, Razer Huntsman Elite | Mice: Logitech G502 HERO wireless, Roccat Leadr | Headphones: Sennheiser HD 700, Hifiman HE1000 V2, Oppo PM3s | DAC/AMP and USB audio enhancers: Schiit Gungnir Multibit, Schiit Mjolnir 2, Sennheiser HD 700, Oppo HA-2 Headphone amplifier, Schiit USB Decrapifier | Webcam: Logitech BRIO 4k | Speakers: Klipsch The Sixes Powered Monitors and MartinLogan Dynamo 300 Stereo Subwoofer with Creative Sound Blaster E5 High-Resolution USB DAC to run them both at the same time. And an Amazon Echo linked at the same time to these speakers via bluetooth on the sound blaster. | Microphone and DAC/AMP: Blue yeti pro, and Focusrite Scarlett 2i2 (2nd Gen) | Router and Modem: Asus rog rapture GT-AC5300, and ARRIS SURFboard SB8200
https://linustechtips.com/topic/647469-games-not-running/#findComment-8330386
3.3 can't be a CPU voltage. Certainly not vcore, and I don't think VDDAs get that high either. Double check exactly what it says, take a screenshot if possible, and make sure everything is what it should. If your motherboard reports some insufficient voltage, it could be your PSU is behind the problem (your mobo does get 3.3v from the PSU, you want to make sure it is not getting 2.9 instead).
https://linustechtips.com/topic/647469-games-not-running/#findComment-8330608
5 hours ago, airdeano said:
due to the AMD platform, a lot of software appz cannot/will not register properly. temps, voltages and other pertinent information can be skewed or just plain wrong.
That doesn't include BIOS, no reason to doubt the information displayed there.
It also won't cause computer crashes as described by OP.
https://linustechtips.com/topic/647469-games-not-running/#findComment-8332188
