Hi, this is the list:
Part List
CPU AMD FX-8350 BOUGHT
Motherboard Gigabyte GA-970A-DS3P $54.99 *
Memory Corsair 8GB BOUGHT
Subtotal: $891.43 *
Mail-In Rebates: $60.00 Total: $831.43
Estimated Wattage: 494W
Im planning to buy COOLER MASTER eXtreme Power Plus RS-550-PCAR-E3
Is it enough? I think the GPU need more power than normal 7970. Does this power supply have enough connectors for my system?
ATX12V or ATX? what type of PSU i need?
I choose that mobo because it has internal USB3.0 header. But it's 970 chipset, will my system perform at max?
I dont want to buy expansive PSU, Chasis etc, because I invested more on GPU and CPU.
I don't plan to do crossfire.
Thank you very much for helping me
https://linustechtips.com/topic/64720-choosing-power-supply/
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/64720-choosing-power-supply/#findComment-885243
I would get the XFX Core 650W:http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014 You could get a 550W version of this but  your overclocks will be limited.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/64720-choosing-power-supply/#findComment-885282
