Hello I'm new to LTT forums but I have a conundrum I have a amd 8320 with arctic freezer 13 and I'm having cpu problems nor getting into details but every 30 mins cpu cold dies not ram or gpu or mobile tried with all different parts so I'm running a old x4 athlon which is getting obliterated by overwatch I ordered 970 prior to this failure so I have no savings until Christmas I have 115 pounds i'd like to get a oldish i7 and moBo please give me suggestions and websites I can look on needs to be available to order in europe or cheap shipping
https://linustechtips.com/topic/646929-cpu-upgrade-help/
Your best bet might be to RMA that 8320.
But for 115 pounds you might be able to get a new FX 8300 or 8320E
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324629
What does rma mean
Very true I have a 1336 lga and 1151 motherboard I got give of a mate but he sold both cpus if that helps
10 minutes ago, PCNoobie said:
Getting a good cpu with 115 pounds is nearly impossible, and if you are getting a different socket type of cpu, then you have to buy motherboard too. You definitely have to buy used cpu, and mobo.
Yeah I'm definitely getting used parts sick of amd last 5 years cpus have been bad I quit with them
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324667
If you have something like Craigslist, I'd search for a Sandy Bridge combo if the seller is willing to test and show that it works.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324675
Just now, mycpuburnsme said:
What does rma mean
RMA means contact AMD to see if you can get the CPU replaced for free.
Computer Specs:
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324685
Mind if I ask what your budget would be for a build?
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324687
Yes sorry for writing so brash, should of included it
1 minute ago, PCNoobie said:
So, you have the mobo already?
I over clocked it to 4.4ghz ? I won't be able to will I?
For a whole build my current value is around 800 pounds I bought
My cpu at release then after market cooler
16gbs of 1600mhz g.skill ram at the time was near a hundred pounds about 75ish two kits of 8gb kits 4x4
Bought big full tower by some weird company was 70
Old graphics card what's 670 now have 970 two 250gbs ssds in raid as oss and 1tb hybrid drive as games movies torrents etc
6 minutes ago, LabRat said:
rewrite that mess and use punctuation.
I'm on my phone or I would.
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324724
Did you test to see if you have issues while not OC? It might just be an unstable OC
Computer Specs:
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324730
I just noticed OP's name and picture...
The horrified face of anyone still using AMD...
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324753
Very true but it's lasted 3 going on 4 years running at high over clocks competing with my friends 3770k and from release it's had its time and I'm not going amd anymore unless the second cpu I buy dies or zen is amazing
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324762
If you have the boards for 1150, try to find a cheap Pentium 325x or i3-41xx. That should last you for a while.
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324774
If you already have a LGA 1150 motherboard, you should be able to pick up a used Haswell i5 for about your price.
Computer Specs:
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324783
It's 1151 and a lga 1336 too oldish mobo by gigabyte
Oh, used i5 6400 or 6500
Or an i3-6100. But you said you had a bigger budget for a big upgrade?
Computer Specs:
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324809
The 6th gen would be too much yeah I'll have a bigger budget by October or Christmas time
But then I'd have to go without gaming massive bottle neck with the 970 and the athlon I have such a bad expierance
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324835
27 minutes ago, mycpuburnsme said:
Will they bottle neck tho that's why I was looking at first gen i7s because of my Asus 970
Not by a significant margin. If you're looking for a more permanent solution I'd take the 6300 or 6500 like Energycore suggested. No bottlenecks.
Edit: Will a 6700 non-K be in your budget?
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8324928
Getting back on my pc I'll look now
Add me on Skype I need a Lil help
Jake.butterfield69
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8325022
Jake.butterfield69
I don't use Skype. Feel free to PM me.
https://linustechtips.com/topic/646929-cpu-upgrade-help/#findComment-8325032
