Hey everyone,
First here is system specs.
Motherboard: Gigabyte X58-UD7 Latest BIOS
Cpu: Intel Core I7 920 D0 stock clocks
Ram: 8 GBs DDR3 1333 Mhz
Samsung 850 SSD 250 GB
2 WD 1 TB Drives
OS Windows 10 Home 64 Bit / Linux Mint 18
Sound: Logitech G430 headset and Realtek Internal Sound
So my problem is whenever I go to open a program and make the computer work at all any sound or even mouse movement stutters as its trying to open said program or even load a web page. Im thinking it may be CPU related but wanted another opinion. I have tried different hard drives and ram but still the same. A reboot fixes it for a minute or so but it immediately comes back. Happens in linux aswell.  But this being said I can convert a avi file to dvd and nothing stutters
I have also tried aida64 for a solid 8 hours and nothing errord out so im not sure
Thanks ahead of time
https://linustechtips.com/topic/646927-pc-stuttering-issues/
nvidia graphics card? sound driver issue? auto search nvidia software?
update adobe flash?
sound driver conflicts with hardware?
heat issues?
auto update software/any software
motherboard going bad?
cpu going bad?
PS going bad?
start disconnecting hardware and stopping software until you can narrow it down. That includes both HD's.
https://linustechtips.com/topic/646927-pc-stuttering-issues/#findComment-8324671
update adobe flash?
heat issues?
cpu going bad?
PS going bad?
Sorry forgot its amd HD7850. temps are nominal and it happens on a fresh install of windows after about 20 mins. It could be motherboard. It does seem to happen when accessing a certain drive. Thanks will look into that.
https://linustechtips.com/topic/646927-pc-stuttering-issues/#findComment-8324695
