First Build
Go to solution Solved by Ichi,
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($319.99 @ Newegg)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($114.49 @ SuperBiiz)
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard  ($142.98 @ Newegg)
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3000 Memory  ($84.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($158.06 @ Newegg)
Storage: Western Digital Blue 4TB 3.5" 5400RPM Internal Hard Drive  ($129.13 @ B&H)
Video Card: Asus GeForce GTX 1080 8GB STRIX Video Card  ($629.99 @ SuperBiiz)
Case: Phanteks Enthoo EVOLV ATX ATX Mid Tower Case  ($154.99 @ Newegg)
Power Supply: SeaSonic X Series 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($121.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($88.88 @ OutletPC)
Monitor: Asus MG279Q 27.0" 144Hz Monitor  ($559.99 @ SuperBiiz)
Total: $2488.29
Generated by PCPartPicker 2016-08-21 06:28 EDT-0400
Most if not all the components are black though...
I've recently been trying to find parts for a custom gaming pc for that i'm willing to spend around 2700 - 3000 on. I don't have plans for overclocking. Here's the list of parts, and was wondering if there were any suggestions for it.
Corsair CX Series, CX600, 600 Watt
Samsung 24x SATA DVD+RW DVD-Writer(just in case)
Intel 730 240GB SSD
Intel i7 6700K(overkill?)
Corsair Dominator Platinum 16GB (2x 8gb)
Corsair h100i
Corsair Graphite 780T(black)
MSI gaming geforce gtx 970
ASUS rog maximus viii extreme/assembly(overkill?)
WD blue 1TB
if the 6700k is overkill the i7-4790k is another option.
https://linustechtips.com/topic/646603-first-build/
If you're just planning to game, get a i5-6600K (if you plan to overclock. if not get a i5-6600) and use some of the money saved to get yourself a 10 series GPU
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
https://linustechtips.com/topic/646603-first-build/#findComment-8320919
Also if you want to save some money get Corsair LPX ram, they're decent for the price
https://linustechtips.com/topic/646603-first-build/#findComment-8320923
2 minutes ago, Ichi said:
His budget is super healthy man.
Well I think he should get a 6600K and use the saved money on say a GTX 1070, which is much much better then a 6700K with a 970
https://linustechtips.com/topic/646603-first-build/#findComment-8320935
1 minute ago, JohnnyCowboy1098 said:
What do you mean by that?
Quite a lot...
12 minutes ago, JohnnyCowboy1098 said:
Ok, i didn't know that, i'm relatively new to building computers, as you can tell by the title of the post. And yes, that's in us dollars.
I'll make a list with at least a 6800k and 1080. Give me 5-10 minutes.
At this budget, trying to save money by skimping on components is a little stupid.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/646603-first-build/#findComment-8320943
1 minute ago, Ichi said:
$3k can easily get you 6700k + 1080.
Well yeah lol, i guess if he wants he can get a 6700 and a GTX 1080. Seeing as he does not intend to overclock
https://linustechtips.com/topic/646603-first-build/#findComment-8320946
Can even SLI that 1080 if he wanted to, but yea, I would be super grateful with single 1080 anyday anytime, lol.
I don't see myself spending 3k on one hobby as I'm into cars as well and car is a bitch to maintain.
https://linustechtips.com/topic/646603-first-build/#findComment-8320953
Ya, i'll be adding a monitor to the mix so I'm trying to squeeze that in to the budget as well. So probably won't be having an SLI anytime soon.
https://linustechtips.com/topic/646603-first-build/#findComment-8320957
13 minutes ago, JohnnyCowboy1098 said:
Ok, i'll wait for your list Randomness.
Please quote people or tag them with @<name> (ex. @JohnnyCowboy1098) if you want a fast response. Also, SLI 1080s with a monitor is easy.
CPU: Intel Core i7-6800K 3.4GHz 6-Core Processor  ($419.99 @ B&H)
Motherboard: ASRock X99 Taichi ATX LGA2011-3 Motherboard  ($219.99 @ SuperBiiz)
Memory: G.Skill TridentZ Series 32GB (4 x 8GB) DDR4-3200 Memory  ($184.99 @ Newegg)
Storage: Samsung 850 EVO 500GB M.2-2280 Solid State Drive  ($169.99 @ B&H)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive  ($309.11 @ B&H)
Case: Fractal Design Define S w/Window ATX Mid Tower Case  ($79.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($90.99 @ NCIX US)
Total: $2219.53
Generated by PCPartPicker 2016-08-21 06:08 EDT-0400
Ill let you choose the monitor c: Install Windows and most used programs and games on the M.2 drive and everything else on the SATA SSD.
USEFUL LINKS:
https://linustechtips.com/topic/646603-first-build/#findComment-8320974
PCPartPicker part list: http://pcpartpicker.com/list/8JVj2R
Price breakdown by merchant: http://pcpartpicker.com/list/8JVj2R/by_merchant/
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard  ($142.98 @ Newegg)
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3400 Memory  ($104.99 @ Newegg)
Video Card: Asus GeForce GTX 1080 8GB STRIX Video Card (2-Way SLI)  ($629.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA T2 850W 80+ Titanium Certified Fully-Modular ATX Power Supply  ($159.99 @ Newegg)
Total: $2549.52
Generated by PCPartPicker 2016-08-21 06:10 EDT-0400
https://linustechtips.com/topic/646603-first-build/#findComment-8320980
Total: $2219.53
That M.2 SSD is not faster than the regular 850 EVO as it also runs on SATA 3. It gets much hotter though. You will have to get the 950 PRO if you want something faster. And also if the main purpose of the build is gaming then a 6700K would be a better option.
https://linustechtips.com/topic/646603-first-build/#findComment-8320989
