4 minutes ago, silverjay928 said:
Hello I was wondering when I am over clocking an AMD cpu it always as a base clock of 200, if I change it to 100 and start over clocking will that help, hurt or make no difference?
it would help if the base clock will be higher, but i dont know if you should change the base clock. if the base clock is tied with other thing (like the southbridge). your system will not boot
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
OK thanks I was thinking that.
but you can try, and then resett the cmos i think
Build
The AMD CPUS bclk wont go down to 100. I believe 185 is the lowest it will go anyways. What AMD processor are you running?
Main Rig:
| 13900K@6.1/4.7 w/TVB | Corsair h150i Elite LCD | Sapphire NITRO SE+ 6900XT@2710MHz | ASUS Z790 Strix-E | Corsair DDR5 Dominator Platinum 2x16GB@6200MT/s | Lian Li O11 Dynamic EVO |
My Folding Stats
Also if he changes the bclk the south bridge and north bridge will automatically scale up the frequencies since the bclk controls practically everything from ram to the bridges and buses.
Main Rig:
My Folding Stats
thus he should not touch the baseclock
Build
Well if he changes the CPU multiplier higher as well he needs to change the multipliers on the North and South Bridge respectively, and the bclk is a fantastic way to squeeze out every last MHz from the cpu. there will be no detrimental effects unless he fails to provide the proper voltage. I did similar things to my 8320 before I upgraded. I think mine is one of the 8320s up there in the Cinebench doc, not including the ones with exotic cooling.
Edited by MysticalRainXIV
Changed CPU model to 8320 oops
Main Rig:
My Folding Stats
