2 minutes ago, rrubberr said:
Specs? Recent hardware additions / upgrades? New software? OS upgrade?
Intel i5 6500
GTX 960 4GB
MSI Z170A PC Mate- Mobo
16GB DDR4 2133mhz
1tb hdd
CM storm devastator 2- mouse and keyboard
Windows 10 Home 64 bit
Just bought the PC for about 3 weeks ago
https://linustechtips.com/topic/646497-help/#findComment-8319543
Did you update motherboard bios, graphic card driver, and or windows yet?
CPU: i7 5930k  |  Motherboard: EVGA X99 Classified  |  RAM: 32 GB Crucial DDR4  |  GPU:  R9 290 Reference Tri-Crossfire w/Kraken g10 mod  | Case: Corsair 780t  |  Storage: Sandisk 960GB SSD, Crucial 960GB SSD, 128GB Sandisk SSD, Seagate 2TB Hard Drive, Seagate Archive Drive 8TB, HGST Deskstar 4TB  |  PSU: Rosewill Gold Lightning-1300, Display(s): Nixeus Vue 24"144Hz FreeSync, 50in TV, Yiynova MVP22U(V3) Tablet Monitor w/ Mechanical Arm  |  Cooling: Cosair H55, H105, 2*Kraken X41  |  Keyboard:  Rosewill Mechanical Brown Keyboard| Mouse: MX Master, G602  | Sound:  Sennheiser HD 700, Westone W40, SoundBlaster e5, Fiio e18
https://linustechtips.com/topic/646497-help/#findComment-8319713
https://www.msi.com/Motherboard/support/Z170A-PC-MATE.html#down-bios
It should have other drivers & instructions in that website too. I'm pretty sure you can update your bios with a usb in bios or straight up from windows.
https://linustechtips.com/topic/646497-help/#findComment-8319758
9 hours ago, LabRat said:
you had this thing for 3month's. did you think of returning to place of purchase. there should be a certasin amount of time to get some warranty service.
i wouldn't mess with the bios.
what's cooling the cpu?
can you post a pic of them pc with the side off the case?
Just the stock heatsink
https://linustechtips.com/topic/646497-help/#findComment-8321658
