So this is my first pc build and while I'm already fairly locked in on most of the parts I'm struggling with the power supply a bit.
Right now my build is as follows:
intel 6700K (already purchased)
asus Z170-AR (already purchased)
Zotac gtx 1070 amp edition (already purchased)
2X8gb ddr4 hyperx fury black
samsung 850 evo 250gb ssd
western digital 1T 7200rpm hdd
cooler master hyper 212 cpu fan
I know I only need about 450w-500w but the thing I'm concerned with is that the 1070 needs 2 8pin connectors which I'm not sure is super standard and may require something special.
Thanks!
https://linustechtips.com/topic/646486-1st-build-need-psu/
1
dont worry you can always use a molex adapter.
BTW use pcpartpicker links it really helps us here
https://linustechtips.com/topic/646486-1st-build-need-psu/#findComment-8319465
