after you install the new motherboard get ride of all the old drivers.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/646399-swapping-mobo-help/#findComment-8318197
So i guess i do this:
1. Backup (if needed)
2. Swap motherboard
3. Enter BIOS in the new motherboard and install a fresh windows 10 (i guess that remove all the old drivers)
4. Download the driver for the motherboard.
Is this correct?
https://linustechtips.com/topic/646399-swapping-mobo-help/#findComment-8318325
2. Swap motherboard
Is this correct?
no windows will still be installed. what you need to do is to get your old motheboard drivers off of the hard drive before step 4 and after 2
https://linustechtips.com/topic/646399-swapping-mobo-help/#findComment-8318744
