I built my PC about 2 years ago. My specs are:
AMD Athlon X4 860K overclocked to 4Ghz (I have a water cooler it never goes above 50 degrees)
XFX 250e (yes I know it's crap didn't know at the time that much about PC's)
8Gb DDR3 corsair memory
CS 430 PSU
Asus A55-BM Plus Motherboard
STARTED with windows 7 ultimate and upgraded to windows 10
corsair hydro all in 1 cooler
1 500gb boot HDD Western digital blue
1 1TB storage HDD Western digital blue
The problem I am having is that whenever I leave my PC for 3-6+ minutes untended without a video playing or me moving the mouse it shuts itself off. This also happens in sleep mode. I will leave, put the computer in sleep and then 3-6+ minutes later it turns on, then shuts off.
Another thing that has happened is whenever turning the PC on it just sits at the windows 10 loading screen and lags, I then have to hit the reset for it to boot and it trys to update but gets stuck at the update so I then have to hit the reset a second time for it to fully boot in.
I have been trying to figure this out on my own but I have had no luck in the past 3 months of this happening. I believe it to be some sort of virus but for all I know it could be something to do with windows 10. I never had this problem with windows 7 but that said, I have had windows 10 since it came out and the problem only started 3 months ago. I know that I could probably just set the pc to backdate itself to 4 months ago when it was running fine but I have several new games, and several photos on my computer that I would not like to lose in the process. If anyone has some ways that I can look at what might be causing this to happen or any ideas on how to fix it PLEASE help!!!
https://linustechtips.com/topic/645897-hella-big-pc-problems/
Do you know how to boot into another operating system, possibly off of a USB Drive? Possibly a pen version of Xubuntu or Ubuntu? That way you can see if its your windows install doing it, or just your computer itself.
CPU: Intel Core i7-7700 GPU: NVIDIA GTX 1070 Cooling: N/A  Motherboard: N/A  Ram: 32GB
HDD: 4TB RAID 1 Array (two 4TB)  PSU: N/A Case: N/A OS: Windows 10 Mouse: Something Something Logitech
Keyboard: Razer Blackwidow 2016 Headphones: Audio Technica ATH-M40X Speakers: ??? Monitor: 2 x HP 22cwa  Phone: OnePlus 3T (T-Mobile Network)
https://linustechtips.com/topic/645897-hella-big-pc-problems/#findComment-8313190
No I don't sadly. Is it easy to learn?
https://linustechtips.com/topic/645897-hella-big-pc-problems/#findComment-8313197
I hate this guys voice, but he gets his point across.
https://linustechtips.com/topic/645897-hella-big-pc-problems/#findComment-8313238
