First off, I am not sure if this is the right category to be placing this topic under, so I apologize in advance if that is the case. Anyways, I recently bought brand new pieces in order to build a new PC. I am fairly new at building one, but I do have the basics down. I assembled the pieces and powered on the computer, however the front and back panels would not send any power; the external devices were not receiving any type of power (the keyboard, mouse, monitor, etc). When powering on the computer, the fans, along with the CPU cooler, are all spinning (with exception to the LED fans in the front of the corsair carbide 400r), lights on the mobo and graphics card are on, but that is about as far as it goes. There may be a small chance that something is seated wrong, though I am pretty sure that is not the case (though I will be double checking). What I am worried about is the possibility that one of the devices may not be compatible, maybe I overlooked something and ordered a wrong piece. Otherwise, maybe something came in doa. A friend of mine believes that the motherboard is NOT compatible with the graphics card, so either the motherboard AND the CPU have to be changed, or a new GPU needs to be inserted. Tell me what you guys think, all the help is much appreciated. Here is the list of the rig with direct links all ordered from Newegg:
Case: Corsair Carbide 400r
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139008
Motherboard: MSI 970 Gaming
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130790
PSU: Corsair HX750i
http://www.newegg.com/Product/Product.aspx?Item=9SIA85V4AH5079
CPU: AMD FX-8300
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113399
GPU: MSI Radeon R9 380
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127878
HDD: 1TB Western Digital
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
RAM: Corsair DDR3 Vengeance 2x 4gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233180
CPU Cooler: Cooler Master Hyper 212-EVO
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
https://linustechtips.com/topic/645583-new-build-first-boot-problems/
did you connect both a 8-pin and a 24 pin from the psu to the motherboard?
It may be worth it to rebuild the computer outside the case
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Just now, Charly0927 said:
yeah both the 8pin and 24pin are in. Would it make a difference that the mobo has 2.0 PCI-E while the GPU has 3.0 PCI-E?
Nah that's not it
I wrote a guide and you can find it in my signature. Make sure the mobo has either a display of POST codes, or a speaker to tell you that POST was completed
Computer Specs:
true, very tru. i should have looked at theboards fan connectors. it def is labeled clearly lol. i know though sometimes, like on my Asrock 990fxextreme9, theres 2 cpu fan connectors right next to each other, along with another chassis pin. i get confused sometimes lol
