Getting a BSOD error - irql_not_less_or_equal...
I've seen many things of what it is. Need some opinions. Doesnt happen often.
CPU : i7 4790K // GPU: MSI 980Ti 6G // CPU Cooler: LEPA AquaChanger 240 // MOBO: Gigabyte GA-Z97X-SLI // RAM: 16GB HyperX Fury @ 1866 //    Case & PSU // Fractal Define S & EVGA 750W
https://linustechtips.com/topic/645551-bsod-help-please/
I have seen this on a bad overclock personally. Recommend bumping your voltages up if you can. If not, dial back your OC.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/645551-bsod-help-please/#findComment-8309470
Do you have a program called KSM? Often used to crack windows office or other applications
https://linustechtips.com/topic/645551-bsod-help-please/#findComment-8331671
