Liquid Cooler Placement
Go to solution Solved by Bananasplit_00,
i would mount it at the back because otherwise arent you just sucking in cold air only to instantly heat it up a bit? it makes more sense to me to have it at the rear and motherboard VRM cooling is usiually fine tbh
Hey guys,
I'll be picking up an NZXT S340 case soon, and after having watched some reviews on YouTube, I realized that my cooler, the Arctic Liquid freezer 120 might not fit in the front of the case, which is where I would like to mount it. Can you guys please inform me if it will fit in the front of the case, if not, where else could I mount it. I I put it in the rear of the case, it will cover up my motherboard and I don't know if that'd good for proper cooling of the VRMs. So, where should I mount my cooler in the S340?
https://linustechtips.com/topic/645329-liquid-cooler-placement/
Builds:
https://linustechtips.com/topic/645329-liquid-cooler-placement/#findComment-8307215
Ok, Thanks
https://linustechtips.com/topic/645329-liquid-cooler-placement/#findComment-8307220
