My friend has just got his Corsair H90 and a AMD FX8350, along with his other components (happy days!).
We've just assembled it and powered it on, and it works. However, I popped into the BIOS to check the watercooler is working, and I suspect it isn't. We left the system running for 5 minutes, and the CPU temp has gone up to 45C, and its not even doing anything.
He's installed it all correctly. Pump, radiator, fans, etc. The pump has been plugged into every 3/4 pin header, but it still doesn't work. I've even tried downclocking the CPU to 3.4GHz (4GHz stock), but still no joy.
Any suggestions?
https://linustechtips.com/topic/644989-corsair-h90-problems/
It's working as intended. Water cooling isn't magic, a single fat-rad won't yield 30C at full load.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/644989-corsair-h90-problems/#findComment-8303620
It is only a single 140mm rad, it will perform the same as a big air cooler will, if you want low temps go for a 240mm rad or bigger, plus the 8350 is not a cool chip in the first place.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/644989-corsair-h90-problems/#findComment-8303750
