Plugging A Surge Protector Into an UPS
Go to solution Solved by Guest,
So you're telling me to use the surge protector going to the UPS, right? Buddy choose me one!!! Please here are the links-
http://www.amazon.in/s/ref=sr_nr_p_85_0?fst=as%3Aoff&rh=i%3Aaps%2Ck%3Asurge+protector%2Cp_85%3A10440599031&keywords=surge+protector&ie=UTF8&qid=1471425664&rnid=10440598031
I have a Corsair VS550.  In my city there's no heavy power surges as far as I know (I may not be politically correct) but I use an UPS of APC  ( http://mdcomputers.in/products/desktop-acessories/ups/apc-back-ups-600va-230v-bx600c-in.html )
-Check out the photos below-
**Problem**-  The UPS uses Indian socket system which don't follow the American plug diagram and different style. I was using a surge protector (a cheap one of with Belkin 200 joules or less :/:S:/:() to plug the PSU power cord for the noted cause. Before I bought an UPS, I used to use the machine directly through the power line and in the meantime, my graphics card started to show malfunctions. So eventually I ended up buying an UPS. Here's the thing, is it bad to use the UPS, connected to a surge protector? APC Says something here- http://www.apc.com/us/en/faqs/FA158852/. Truth to be told, what could I do except doing this? I had no other option going along with the given power cord provided by Corsair and plugging into the surge protector at the time and still now. I was baffled and the same still now.
ADVICE!!!!
- Corsair Plug type that I got
APC UPS Socket. different from the PSU power cord pattern.
https://linustechtips.com/topic/644652-plugging-a-surge-protector-into-an-ups/
plug the UPS into the surge protector, not the other way around.
I have a UPS, and I have plugged a surge protector into the UPS. There is nothing wrong with it, it's just that the surge protector can detect the sine wave output from the UPS as a surge, and so the surge protector may not protect you against surges anymore because it used up all its surge protecting ability. If you plug the UPS into the surge protector this wouldn't be a problem. You won't damage your computer components either way.
hello!
is it me you're looking for?
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
Cooler: Dark Rock Pro 3
RAM: 32GB DDR4
GPU: GTX 1080
Storage: 1TB 850 Evo, 1TB HDD, bunch of external hard drives
PSU: EVGA G2 750w
Peripherals: Logitech G502, Ducky One 711
Audio: Xonar U7, O2 amplifier (RIP), HD6XX
Monitors: 4k 24" Dell monitor, 1080p 24" Asus monitor
Laptop:
-Overkill Dell XPS
Fully maxed out early 2017 Dell XPS 15, GTX 1050 4GB, 7700HQ, 1TB nvme SSD, 32GB RAM, 4k display. 97Whr battery :x
Dell was having a $600 off sale for the fully specced out model, so I decided to get it :P
-Crapbook
Fully specced out early 2013 Macbook "pro" with gt 650m and constant 105c temperature on the CPU (GPU is 80-90C) when doing anything intensive...
A 2013 laptop with a regular sized battery still has better battery life than a 2017 laptop with a massive battery! I think this is a testament to apple's ability at making laptops, or maybe how little CPU technology has improved even 4+ years later (at least, until the recent introduction of 15W 4 core CPUs). Anyway, I'm never going to get a 35W CPU laptop again unless battery technology becomes ~5x better than as it is in 2018.
Apple knows how to make proper consumer-grade laptops (they don't know how to make pro laptops though). I guess this mostly software power efficiency related, but getting a mac makes perfect sense if you want a portable/powerful laptop that can do anything you want it to with great battery life.
But you missed the point of the PSU power cord thing. There's no socket compatible for the power cord, so what'll be the point of having an UPS?
buy an adapter, if you can't get one, just keep on using the current setup you have, there is nothing wrong with it.
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
