Wish I would have found this forum a few months ago, but this is what I currently have (and aim for). Any suggestions on optimizing would be fantastic :)
guts:
Asus X99 Sabertooth MB
i7 6900k CPU
64gb (8 x 8gb) Corsair Vengeance LPX DDR4 2666mhz C15
evga geforce GTX 1080 FTW x2 with nvidia HB SLI bridge
512gb Samsung 950 Pro NVMe SSD (OS / apps)
4tb Seagate something or other local storage HDD
Creative Sound Blaster Z PCI-E sound card
Corsair HX1000i power supply
Case is Cooler Master HAF X
Cooling:
top mounted Thermaltake Water 3.0 Ultimate AIO, with 3 Noctua NF-F12's pushing up out the top (actually concerned because the rad end towards the front of the case has no mount points - it's just hanging)
top: Phanteks PH-F200SP x2
rear: Noctua NF-P14 redux
front: Noctua NF-A14 (mounted in 4ish 5.25" drive bays), BitFenix Spectre Pro 230mm
side panel: Phanteks PH-F200SP
internal: NF-S12B redux (on VGA cooling bracket mounted to HDD cage blowing over PCI-E slots)
Accessories:
keyboards: originally MS Ergonomic 4000, but recently got the mechanical bug and added WASD 87-key with Cherry MX browns, Cooler Master Quickfire TK with blues, and Razer Orbweaver chroma keypad.
mouse: Logitech G500s (love the weight and size, same as my old G500. Haven't found a more comfortable mouse yet)
displays: Asus PG348Q 34" curved 3440x1440 @ 100hz G-Synch primary, Asus PG278Q 27" 2560x1440 @ 100hz (yes I know it does 144hz) secondary. I want to add another of these on the other side for surround setup.
webcam: Logitech C920
mic: blue snowball
Sound:
Sound only goes out via DTS Connect on optical cable to my AVR to a 7.1 system around the room, so no PC speakers, and I can't really see headphones making sense at the moment.
It plays Minesweeper really well, and LTT YouTube videos are nice and crisp.
Any tips or suggestions on optimizing the setup?
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
https://linustechtips.com/topic/644252-suggestions-for-do-it-all-current-build/
haha thanks. I haven't been keeping track of the cost to be honest... just figuring out what I wanted and piecing it together over the last few months.
Do you have any suggestions for stuff I am overlooking or missing? AFAIK after adding the 2nd side screen i can't think of anything else that would complete the setup.
bump
so I am not missing anything as far as you guys can see?
bump again
nobody has any suggestions?
  • 2 weeks later...
one last bump in hopes that somebody will be able to find something I have overlooked...
Still running Minesweeper just great. I swapped the SLI bridge to an EVGA one so the color would match but other than that i think it's really done. Haven't found a great guide on 6900k OCing yet so it's still running stock. While running WoW in fullscreen exclusive mode on at 3840 x 1440 I have been able to get the CPU cores up to about 34C max, but the primary GPU is running about 20 degrees hotter than the 2nd one (I think because one of it's fans is obscured by the sound card, so I am looking into a 1x PCI-E extender to move the SB-Z to the lowest slot on the case.
Anyway, I hope somebody will be able to offer some tips or suggestions. Kind of just threw this together blind but everything seems to be working just fine.
