Hello there im looking to build my first pc (MATX) in about a month or 2 but i want to get whats best for me so i would like some ideas on what parts would be good.
I dont really have an order im just going to list parts and links.
Case: https://www.overclockers.co.uk/corsair-carbide-series-88r-micro-atx-case-black-cc-9011086-ww-ca-212-cs.html
GPU: https://www.overclockers.co.uk/gigabyte-radeon-rx-480-g1-gaming-4096mb-gddr5-pci-express-graphics-card-gx-18e-gi.html
CPU:http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16819117564&nm_mc=KNC-GoogleUKAdwords-PC&cm_mmc=KNC-GoogleUKAdwords-PC-_-pla-_-Processors+-+Desktops-_-N82E16819117564&gclid=CMXKzKOCxc4CFekW0wodMu4HkQ
PSU: https://www.scan.co.uk/products/550w-corsair-rm-series-80-plus-gold-full-modular-sli-crossfire-single-rail-1x140mm-fan-atx-v24-psu-r
SSHD: http://www.novatech.co.uk/products/components/harddrives-internal/satahybridssddrives/Seagate/ST2000DX001.html?gclid=Cj0KEQjw-Mm6BRDTpaLgj6K04KsBEiQA5f20E5HmoFE6GAyP_hbabGIZrYXf4BKz6lMJq6RnjQXRU3caAmV_8P8HAQ#utm_source=google&utm_medium=base&utm_campaign=products
WIFI Card: http://www.ebuyer.com/728214-tp-link-ac1300-wireless-dual-band-pci-express-adapter-archer-t6e
i know im missing out on a motherboard and ram thats what id thought id ask you guys and gals what you would get considering im a first time builder.
If there is anything you would change or if there is something ive missed out just tell me thank you very much for reading this far.
https://linustechtips.com/topic/644062-need-help-with-first-pc-build/
I would use one of this wifi cards instead:
https://www.asus.com/us/Networking/PCEAC68/
https://www.asus.com/us/Networking/PCE-AC88/
https://www.asus.com/us/Networking/PCEAC56/
That SSHD inst actually very good, youd be better off with a 120 or 240GB ssd, and a 1tb drive, if you whant a silent one go for a green or red if you whant one with the best performance go for a black.
That PSU is a little bit outdated, you should go for the newer version
http://www.corsair.com/en-us/rmx-series-rm550x-550-watt-80-plus-gold-certified-fully-modular-psu
Id go for a different brand GPU, Asus if you whant good performance ou off the box, MSI if you are going to overclock.
In relation to ram, do you whant cheap ram, expensive ram or somewhere in the middle?
Any of these two would work, depends on how mutch you whant to expend.
https://www.asus.com/Motherboards/MAXIMUS-VIII-GENE/
https://www.asus.com/Motherboards/Z170M-PLUS/
If you used a atx or mini itx mobo you could get one with integrated wifi, you sure you whant to use a matx?
