Hey, so the ATT agent just left my house. So my problem is my wired desktop computer when in use takes all the speed from the wireless. When the computer is in use we only get like 1-2 megbits when its usually 24. Now is there a way I can limit the speed going into the wired computer so there is more to be used on other devices?
https://linustechtips.com/topic/643989-internet-help/
something maybe using up bandwidth in the background on your pc. Check task manager and see what the network activity is like . You can limit the speed at on the router but only on certain models.
15 minutes ago, Artiom916 said:
But I game on a daily basis so i cant. If i get more speed lets say 50mbs isntead of 24bs would it will just take the 50mbs speed or will there be more to share among other devices.
It depends on what it using all the bandwidth in the first place. but realistically yes there will be more to share
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
https://linustechtips.com/topic/643989-internet-help/#findComment-8292694
3 hours ago, Torn said:
Gaming generally uses very little bandwidth. Sounds like you have another program using it up. If you're using a p2p program you can limit its bandwidth, if not you may have some sort of malware.
Ok so what exactly am I looking for and how do I know if its safe to unistall?
https://linustechtips.com/topic/643989-internet-help/#findComment-8293400
Go into task manager make sure you have "more details" and in the processors tab sort the "network" column so the highest network usage at the top
https://linustechtips.com/topic/643989-internet-help/#findComment-8293512
