Hello everyone.
I am new here, I would like start building my first gaming PC, I have been saving for almost 2 years.
and now I am really confused what should I use in the build ( sorry for my bad English ) I have a budget of 5000 € and I would like to know if any one can recommend what parts should I use.
I am really keen on NZXT with water cooling, but really I don't know, I would appreciate your help guys.
And thank you so much
https://linustechtips.com/topic/643889-help-please/
when you talk about water cooling do you mean custom liquid cooling or just an all in one system for the CPU?
What are your objectives to complete? 4k 60FPS? 1080p 60FPS? What are your storage needs?
5000 Euro is enough to pretty much build the best money can buy right now. Spending more than 2000-3000 Euro and your in the area of spending ridiculous amounts on money on un-needed hardware.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/643889-help-please/#findComment-8291547
What I am really keen on is 4K gaming and VR, for the cooling also I want it to be custom cooling, for the storage all I want is 1tb.
https://linustechtips.com/topic/643889-help-please/#findComment-8291569
Are you sure you want to do a custom liquid cooling for your first build? I highly suggest against it.
https://linustechtips.com/topic/643889-help-please/#findComment-8291575
I would buy a computer worth around 1500-2000€ now, then save the rest. This will get you a brilliant system by today's standards, and if you want to upgrade in 3-5 years from now, you'll have 3000-3500€ to buy an even better PC than is even possible today.
I edit my posts a lot.
https://linustechtips.com/topic/643889-help-please/#findComment-8291577
You'll want an SSD, even if just a 500GB one for a boot drive, then maybe a 1TB WD black HDD to go with it.
https://linustechtips.com/topic/643889-help-please/#findComment-8291580
5000 Euro is waaay too much for a computer, you're better off spending 2500 today, and getting a car or something with the rest :)
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/643889-help-please/#findComment-8291581
What brands can you suggest ?
https://linustechtips.com/topic/643889-help-please/#findComment-8291586
Where are you from? We can help you find where to buy computer components.
I also highly advise against building a custom watercooling loop for your first time. You'll want either an air cooler or an AIO.
Computer Specs:
https://linustechtips.com/topic/643889-help-please/#findComment-8291593
I know hahaha ? I saved up a lot just to have that safety net, but probably I'll spend around 2000€ - 3500€ And save up the rest of the money.
https://linustechtips.com/topic/643889-help-please/#findComment-8291596
I'm not sure about pre-builts, but the sort of parts you'd be looking at are:
  • Intel i7
  • GTX 1080
  • 16-32GB RAM
  • 500GB-1TB SSD
  • 1TB-2TB HDD
  • 650-750W PSU
I think you should stay away from watercooling for now since it doesn't really add much to cooling and brings a lot more danger to your build.
https://linustechtips.com/topic/643889-help-please/#findComment-8291597
  • Intel i7
  • GTX 1080
  • 16-32GB RAM
  • 500GB-1TB SSD
  • 1TB-2TB HDD
  • 650-750W PSU
thank you for you recommendation I appreciate it.
https://linustechtips.com/topic/643889-help-please/#findComment-8291627
9 minutes ago, HAHHIS said:
I am from Germany
Awesome. Parts list incoming.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  (€349.43 @ Mindfactory)
CPU Cooler: Corsair H110i GT 113.0 CFM Liquid CPU Cooler  (€129.89 @ Amazon Deutschland)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  (€141.90 @ Mindfactory)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  (€94.06 @ Mindfactory)
Storage: Samsung 850 EVO 500GB M.2-2280 Solid State Drive  (€154.84 @ Mindfactory)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (€74.62 @ Mindfactory)
Video Card: *Inno3D GeForce GTX 1080 8GB Twin X2 Video Card  (€686.99 @ Mindfactory)
Case: NZXT S340 (White) ATX Mid Tower Case  (€82.44 @ Mindfactory)
Power Supply: SeaSonic PRIME 650W 80+ Titanium Certified Fully-Modular ATX Power Supply  (€202.34 @ Mindfactory)
Monitor: Asus PG27AQ 27.0" 60Hz Monitor  (€849.00 @ Mindfactory)
Total: €2765.51
Generated by PCPartPicker 2016-08-15 23:54 CEST+0200
Included is an AIO Liquid cooler and a power supply so good, it will last you 20 years. Rest of the build is run of the mill maxed out gaming computer, and a 4K monitor with GSync for added smoothness. The monitor is another of those things that'll last you 10+ years
Computer Specs:
https://linustechtips.com/topic/643889-help-please/#findComment-8291652
2 hours ago, HAHHIS said:
I guess I'll try.
the thing is if you try and fail at a custom loop you ruin the entire PC, costing you thousands...
https://linustechtips.com/topic/643889-help-please/#findComment-8292147
Total: €2765.51
Phwoar that costs more than I expected. Looks good though!
Oh it's the monitor that adds the extra cost. huh.
https://linustechtips.com/topic/643889-help-please/#findComment-8294009
Yeah the monitor is a big chunk of the cost, since it will last you for longer than the rest of the computer components
Computer Specs:
https://linustechtips.com/topic/643889-help-please/#findComment-8295682
