i have an NZXT phantom 630 window edition computer case i had some questions about water cooling like for a loop i need 2 rads correct and i was wondering what the best GPU block CPU block tubing fittings pump and res would be for a water cooling loop and in addition my case has 2   200mm Fans on the top of the case not inside but on top and i was wondering if i was to mount a rad on the top of the case under those fans could i keep them and still add another 2 fans on the rad if i faced them so they pulled the air or something?
https://linustechtips.com/topic/643827-water-cooling/
Punctuation marks? O.o
Anyway you might want to play around with this tool from EK.
https://www.ekwb.com/custom-loop-configurator/
EK makes good quality water cooling parts.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/643827-water-cooling/#findComment-8291675
