Yesterday I tried to figure out why my mic wasn't picking up any sound and as a last resort kinda thing I tried updating the firmware to version 0.005. Now I can't control the mic's volume via the sound card (can't in windows either, which is normal) and even if I change the headset's volume it doesn't make a sound as it used to. I'm using windows 10. I tried it out with another PC as well that it used to work on and got the same results. Is there any way to downgrade back to 0.003 that I was using and if so, where can I download it?
https://linustechtips.com/topic/643100-hyperx-cloud-ii-sound-card-issue/
why do you have a sound card anyway? But it sounds like that is the issue, try plugging in directly into the mobo.
You would have to search on your manufacturers website for the older drivers.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
The headset uses too much power so if I just plug it straight into my laptop it occasionally pops/crackles. The headset is working fine tho, it's 100% an issue with the sound card.
Edit: I tried searching for the older drivers on the website but no luck.
The pops and crackles have nothing to do with the headset and everything to do with the laptops cheap DAC and AMP.
Rip, I like to keep the install files of my drivers for things like my GPU and what not just I case stuff like this happens.
