     Can anyone help me? first time posting on the forums. So my internet is slow..very slow > http://www.speedtest.net/my-result/5549220856 . I currently have a 1tb hard drive that is almost full and I just got a new 240gb SSD I want to use as my boot drive. I do not have an external hard drive so I cannot back up my data in order to clone my disk. So I wanted to do a clean install, but I don't know how to delete the old Operating system on my hard drive in order to use it as a storage drive. The college I go to has very good internet and I was wondering if there is a way to download programs drivers and such without bringing my entire PC to school. I have a laptop (very small storage) I use and do not have an  SATA to USB cable and a 1tb Microsoft OneDrive account. I could really use some help, Thank you :)
https://linustechtips.com/topic/642488-need-help-with-boot-ssd/
Just install fresh Windows onto the SSD.
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/642488-need-help-with-boot-ssd/#findComment-8277272
You can backup crucial files to your OneDrive account since it has 1 TB storage. Install the new SSD to your PC, and migrate OS to the new SSD using some third party software (my suggestion is Partition Assistant standard). These kind of tools help you move operating system to new hard disk in several clicks. After completing, change the boot settings in BIOS, or unplug the old drive to test if the new OS works.
As you mentioned you want to keep the old drive as the storage device meaning delete the previous C drive. If everything works fine. Name the new system drive as C drive and delete the previous one using the same tool in Windows PE mode.
https://linustechtips.com/topic/642488-need-help-with-boot-ssd/#findComment-8287502
