3 minutes ago, GermanPCBuilder said:
I want a cpu cooler for my i5 6500 what do you suggest? How expensive should it be?
You don't need an aftermarket cooler unless you really care about noise and aesthetics
if (you want to reply) {
 USE THE QUOTE BUTTON
else {
 DONT
https://linustechtips.com/topic/642259-cpu-cooler-for-6500/#findComment-8275166
Since you won't be overclocking a non "K" processor (not unlocked), the stock cooler will provide sufficient cooling.
If you're really set on getting an aftermarket air cooler, the Cooler Master Hyper 212 Evo is a good choice. It has excellent reviews and will set you back ~$30 USD. Just make sure it will fit in your case before purchasing.
https://linustechtips.com/topic/642259-cpu-cooler-for-6500/#findComment-8275173
