5 minutes ago, GermanPCBuilder said:
Hey my friend needs a new GPU and his budget is around 220€, what do you suggest?  ( shopping in germany at Mindfacotory.de)
Stretch a little and get this.
http://www.mindfactory.de/product_info.php/4096MB-Sapphire-Radeon-RX-480-Nitro--Aktiv-PCIe-3-0-x16--Lite-Retail-_1114532.html
I can't read that site but I sure know how to use the search function, lol.
Let me know if there's anything wrong with the item in the link.
https://linustechtips.com/topic/642252-need-graphics-card/#findComment-8275062
well you can get a r9 380x close to the RX 480 4GB but costs way less in that online store
XFX Version: http://www.mindfactory.de/product_info.php/4096MB-XFX-Radeon-R9-380X-Double-Dissipation-Black-Edition-OC-Aktiv-PCIe_1021833.html
PowerColor Version: http://www.mindfactory.de/product_info.php/4096MB-PowerColor-Radeon-R9-380X-PCS--MYST-Edition-V2-Aktiv-PCIe-3-0-x16_1060588.html
but id say get the RX 480 or 470 since those are much more energy efficient and in Germany power is expensive.
"Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning." -Albert Einstein
https://linustechtips.com/topic/642252-need-graphics-card/#findComment-8275067
https://linustechtips.com/topic/642252-need-graphics-card/#findComment-8275072
RX 480 or RX 470. Best value
But the 480 is a lot more powerful :D
https://linustechtips.com/topic/642252-need-graphics-card/#findComment-8275073
Just now, GermanPCBuilder said:
Should he go 380X or 470?
if you care about raw power and not energy efficiency then 380x. if you want an energy efficient PC then go for the 470 but the 470 will be weaker than the 380x
https://linustechtips.com/topic/642252-need-graphics-card/#findComment-8275080
not really since the 480 is slightly behind a 390 and a 380x is pretty close to a 390. id say a 380x is just barely behind a 480
https://linustechtips.com/topic/642252-need-graphics-card/#findComment-8275087
No, not really. 390 is over 50% more powerful and with recent updates the 480 is 5-10% ahead of the 390.
https://linustechtips.com/topic/642252-need-graphics-card/#findComment-8275089
RX 480 that I posted is just €20 more and you get 15% performance increase compare to RX470.
That's not even 2 hours of work or if he's a student or something, I'm pretty sure he can ask €20 from his parents.
RX480 is like the sweet spot for now and can easily last you a couple of years.
https://linustechtips.com/topic/642252-need-graphics-card/#findComment-8275091
I think he will get that RX 480
https://linustechtips.com/topic/642252-need-graphics-card/#findComment-8275350
