I am currently helping my friend choose a motherboard. What is the difference between these two?     And we are debating between 6600k or 6500. I think it is going to be 6600k
http://www.ncix.com/detail/asus-z170-a-atx-lga1151-skylake-c4-111462.htm
http://www.ncix.com/detail/gigabyte-g1-sniper-b7-lga-a9-126150.htm
https://linustechtips.com/topic/642075-motherboard-help/
the Gigabyte is a B150 chipset mobo
you wont be able to OC if you use the mobo
only Z170 allows OC of the 6600K
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/642075-motherboard-help/#findComment-8273372
So are all B150 chipset not overclockable?
What about this one? http://www.ncix.com/detail/msi-b150-gaming-m3-atx-33-120220.htm
https://linustechtips.com/topic/642075-motherboard-help/#findComment-8273378
all B and H series chipset cant OC
https://linustechtips.com/topic/642075-motherboard-help/#findComment-8273382
ok so if I go with this mobo http://www.ncix.com/detail/msi-b150-gaming-m3-atx-33-120220.htm I will be going with the 6500k
What is the difference between B150A and B150?
And what are the difference between the B and H chipsets?
https://linustechtips.com/topic/642075-motherboard-help/#findComment-8273386
do you mean 6500 or the 6600K?
6500 go with the B150
6600K go with the Z170
the B150A is just MSI naming
there is only one type of B150 chipset
https://linustechtips.com/topic/642075-motherboard-help/#findComment-8273391
the b- is a business chipset while the h- is the consumer chipset
https://linustechtips.com/topic/642075-motherboard-help/#findComment-8273399
dont forget Q series are also Biz chipset but it wont matter for normal user
you still can use the B150 chipset mobo
https://linustechtips.com/topic/642075-motherboard-help/#findComment-8273403
https://linustechtips.com/topic/642075-motherboard-help/#findComment-8273406
