Hey guys, I'd like to ask for some advice.
Lately I've gotten 2 second hand old pcs, both not very high-end though I'd like to use it as a htpc/server box (for example for minecraft) though I'm unsure if the hardware I have available will be strong enough. Here's the list:
PC 1:
ram: 2GB ddr2
gpu: geforce gt 310
cpu: still have to check, but i think it's a pentium
PC 2:
ram: 2GB ddr2
gpu: geforce 7900s
cpu: core 2 duo e6400
ill probably use the core 2, though im not sure which gpu to use. Aside from these things I have everything else.
Thanks in advance!
https://linustechtips.com/topic/641668-small-htpc/
GT 310 is better but they are both complete and utter shit to be honest here... stick all the RAM in one PC if you can, that will help slightly atleast
Builds:
https://linustechtips.com/topic/641668-small-htpc/#findComment-8269328
