  • 4 weeks later...
Hello,
I've just made my first ever PC build in the Dark Base 900 Pro -here are a couple of photos. It's pretty standard so far (my first attempt). All I've done is remove all the drive cages and lower the mobo to the lowest setting. Sadly, I just RMA'd the motherboard last week so I'm waiting on a replacement. When it comes through, I'll add a 280mm rad in the front and include the gpu in the loop. I'll also flip the top radiator and set it up as a pull exhaust with some 90deg fittings, that way I'll be able to move the radiator towards the back of the case and clean up the tubing.
Also toying with the idea of hard tubing next time...
https://linustechtips.com/topic/641338-dark-base-900-pro/#findComment-8432914
  • 1 month later...
