So with pokemon go being release I am finding that i go through my battery on my iPhone 6s Plus in a day. Before I could get away with only charging my phone once every 2-3 days. With now having to charge my phone daily and the increased rate in which my battery decreases the recharge cycles are going to be used up 2-3 time as fast with increase battery wear decreasing the lifespan of the phone.
My question is that if i buy a battery bank. If I used this while playing pokemon go. Then I won't be using the battery cycles of the phone instead just sitting on 100% charge. I don't know how phone batteries work in detail. My question is will that work or will it still be using recharge cycles, or will it just leech off the power bank?
https://linustechtips.com/topic/640062-saving-your-battery/
It will do a combination of both, but an external battery definitely will reduce the severity of cycling on your phone's internal Li-Ion battery.
Probably the most destructive thing for Li-Ion batteries is very deep discharges.  So the battery pack is a good thing.  The more you can keep the phone charged up the better.  Running it beneath 50% is far more damaging than just repeated cycles of 100% to 60%.
https://linustechtips.com/topic/640062-saving-your-battery/#findComment-8257610
