so I haven't noticed this before but my fallout 4 dips very low like into the the 19 -24fps range while outside of any major city only ever goes to 48 -52 fps when in diamond city or goodneighbor. This started to happen quite recently after I added a few mods to my game but only some clothing and some command mods like non texture related ones. I think it's only in Faloout but I will have to test more games because I used MSI kombustor and it is able to hit power: 122% easily and it'll hit 99% usage like nothing but not in fallout 4. Any ideas on what's happening?
My specs:
4790k 4.4GHz
GTX 980 ti Gigabyte Xtreme
AX 860i
Asus z97 Pro Gamer
pretty much everything else I guess is standard stuff.
https://linustechtips.com/topic/639547-low-gpu-and-low-cpu-usage-issue/
Poor mod programming. I would start by deleting some of the mods and seeing which one is tanking your performance.
I would also check your PC's power plan and make sure it's either on "Balanced" or "high Performance".
what OS are you using?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Well I just played a bit of Witcher 3 and noticed this, the power is very low while the usage is at full I don't quite understand what is doing this.
Windows 10 and the how would I go about setting this plan?
I think the reason your power consumption is low while your GPU is at 99% may be because that power consumption is already considering the increased power limit.
Mods often are badly optimized and may have excessive meshes, what can cause a lot of load on specific components of the GPU, making other components sit on their asses. I'm not sure on that, just a guess out of thin air.
CPU: R7 5700X3DMotherboard: ASRock B550M-ITX A/C | Cooling: Deepcool AG400 Digital w/ Corsair ML120 Elite + 1 ML120 Elite exhaust + 2 ML140 Elite intake
RAM: 2x16GB Netac DDR4 3200MT/s | GPU: Gainward RTX 3080 Phoenix (+212MHz / +1000MHz / -6% PL)
Storage: 2TB XPG S70 Blade, Seagate Barracuda 2TB, Samsung 850 Evo 250GB (caching the HD) PSU: MSI MAG A750GL
Monitor: 2x Pichau Cepheus Fuse 28" 4k 144Hz HDR | Keyboard: Corsair K100 optical-mechanical
Headphone/headset: Kuba Disco Pro/Gamer + Beyerdynamic DT-770 Pro | OS: Windows 11 Home
Mouse: Logitech G502X + Ugreen Ergonomic MouseCase: Corsair Carbide 400C
Is your power plan on balanced? That's all you have to do.
I see that you're on Win 10. Was this problem before or after the anniversary update? If it's after, try rolling back and seeing if it helps.
I would also look if this issue occurs when you have no mods except core mods.
First off the picture I sent is from witcher 3 not modded at all and I am having issues in most of my games not even being able to hit 99% on my gpu usage please read everything.
I didn't have to update anything it just happened after about two hours of not playing it and then get back on and it sarted doing it
Are you using Mod Manager or Mod Organizer? Or just doing manual installs?
