Hi Guys,
I have a problem with my Logitech G27 after I've done the Anniversary Update on Windows 10.
Before that everything did just fine.
The problem is that the clutch pedal and the H-pattern shiter is not registered in any game or even the Logitech Profiler, which sucks, because I used them every time I play ETS 2 Or Project Cars.
I made sure every connector is correctly seated and I used different USB 2.0 ports (USB 3.0 is not supported)
I installed the newest driver from Logitech and now I don't know what to do anymore.
So I hope you have some answers that I can try.
https://linustechtips.com/topic/638483-problem-with-logitech-g27/
Are you able to roll back the update? That would be my first step.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
I did roll back the update and it works like a charm, but now I have all my other problems back that was solved through the anniversary update.
So I think I go back to the anniversary update and just wait for a new driver from logitech and I hope that will fix it.
It will not kil me if I can't play ETS 2 or Project Cars for some weeks.
But thanks for the help.
