I lost my crystal ball yesterday, If you would at least provide language, because looking at your post I cannot think of you providing sample code you have problem with.
But being serious, your post has no information that could be helpful someone to help you, I don't know what language you are using, and the code or at least a part of it would be informative.
https://linustechtips.com/topic/638442-bad-value-problem/#findComment-8235749
The validator is mostly recommending you switch to CSS for your formatting but if you want to do it with CSS then...
Remove the "px" from your height and weight values to fix 1 and 2.
Ignore 3 and 4 if you don't want to use CSS.
For 5 you're missing a value, style equals nothing. You'll need to add quotes and a value or remove style= all together.
For 6 remove the "px" from your height and width again like for 1 and 2.
-KuJoe
https://linustechtips.com/topic/638442-bad-value-problem/#findComment-8235768
He's using HTML, the code is in the screenshot.
-KuJoe
https://linustechtips.com/topic/638442-bad-value-problem/#findComment-8235773
<!doctype html>
<html lang="en">
<head>
	<meta charset="utf-8" />
	<title>Homepage</title>
	<link rel="stylesheet" href="homepage.css">
</head>
<body>
	<div id="container">
		<a href="http://www.brucetelecom.com/NetworkStatusDescription.php?id=43" style="margin-left: 265px; font-family: Verdana; color: #0b479d; font-size: 14px;">Bill payments during possible Canada Post work stoppage</a>
		<br />
		<br />
		<iframe src="frame1.html" scrolling="no" height="125px" width="865px" frameBorder="0">
			<p>iframes are not supported by your browser.</p>
		</iframe>
		<iframe src="frame2.html" scrolling="no" height="325px" width="250px" frameBorder="0" style=>
		</iframe>
	</div>
	<div id="body">
		<iframe src="table.html" scrolling="no" height="335px" width="631px" frameBorder="0" style="float:right;">
</body>
</html>
It`s HTML
https://linustechtips.com/topic/638442-bad-value-problem/#findComment-8237522
