Best Monitor?
Xyren
They're all likely going to have similar or even the same panels.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
I agree with this, but then ACER is probably the most reliable of the listed brands.
Are those your only options? You have ASUS https://www.amazon.co.uk/Asus-VC239H-inch-Full-Monitor/dp/B00YQKTGR8 in a similar range to the AOC. If you stretch your budget you can get this beauty https://www.amazon.co.uk/LG-25UM58-P-25-Inch-21-UltraWide/dp/B01BFH18BG/ and be happy. I'd use a better brand monitor if you weren't getting significant enough discount on the ones in your list.
