I currently have a NZXT noctis 450 case with a Noctua NH-D15 CPU cooler but I'm switching to an AIO one since the Maus like Noctua takes too much space. I want to go for the Swiftech X320 x2 prestige, but I wonder if it will fit in a top config if I remove the noctua 140mm on the top left? The dimensions of the cooler are 127 mm x 375 mm x 28 mm. My case specs says it supports 2x140mm or 3x120mm radiator on top but the cooler seems rather big.
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/637933-does-it-fit/
1 minute ago, Naeaes said:
For a 3x120 radiator, the H320X2 is actually small. Usually radiators have an extension beyond the fans that has the tube fittings but this one doesn't have them. Like here.
I see so it will fit fine?
https://linustechtips.com/topic/637933-does-it-fit/#findComment-8230259
12 hours ago, Naeaes said:
I'd say so, yeah. This guy did it.
ok thx ordered it yesterday, will have it next week
https://linustechtips.com/topic/637933-does-it-fit/#findComment-8234000
