Just got my build up and running, really like the Air 540 so far. I do have one of the revisions with the short USB 3.0 cables so I cant plug it in yet. Got an RMA number pending to fix that. Im very happy with the fit of the Icysdock in the front, right now its not screwed into the 5.25 cage, im gonna have to mod it to screw it in. Also I wanna see if I can change the LEDs to white. Not sure how realistic that is.
post-9340-0-71686200-1381277602_thumb.jp
post-9340-0-94262000-1381277636_thumb.jp
https://linustechtips.com/topic/63765-air-540-build/
Looks great(dem noctuas), you should really improve on the cable management though.
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/63765-air-540-build/#findComment-872145
looks nice but tidy up those cables and plug in the front io from your case
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/63765-air-540-build/#findComment-872174
Nice choice of parts, but there really is no excuse for bad cable management with that case.
Industrial level very high RPM fans and cheapo fans that aren't very good are a possibility
They'll be industrial level 2000 RPM fans, nothing's  stopping you from undervolting them though.
https://linustechtips.com/topic/63765-air-540-build/#findComment-873549
Well really being my AIO water cooler has so many wired coming off the block I dont have a lot of options to manage it better, Thats all getting replaced soon anyways
Nice build. I cant plug in the front usb3 on my air 540 either. :(
If you RMA Corsair they will send you out a longer one, waiting on mine now.
https://linustechtips.com/topic/63765-air-540-build/#findComment-873974
Ok. Thanks for letting me know :)
https://linustechtips.com/topic/63765-air-540-build/#findComment-874039
