Hey guys,
So I am trying to overclock my 6600k with hyper 212 evo and a gigabyte z170 hd3p mobo using Intel Extreme Tuning Utility and I ran into a problem. The benchmark at stock showed 1048 marks. After that, i got into basic tuning and upped the multiplier so that the core and cache should've reached 4.00ghz. So, the cache did that, however, the cpu locks itself at around 3.89ghz. Dropped cache to 3.80 instead of 4.00 and same result. Upped both at 4.20ghz and still 3.89ghz. Any advice?
  • CPU
    Intel Core I5 6600k @ 4.4ghz
  • Motherboard
    Gigabyte HD3p z170
  • RAM
    Kingston HyperX Fury @ 3666mhz
  • GPU
    Asus Strix GTX 1070 @ 2100mhz
  • Case
    Fractal Design Define R5 Windowed Blackout edition
  • Storage
    Samsung 850 EVO 250gb
  • NEW Seagate Skyhawk 2TB
  • PSU
    Corsair RM650x
  • Display(s)
    Dell U2414H
  • Cooling
    CM Hyper 212 EVO
  • Keyboard
    Logitech G810
  • Mouse
    Logitech G502 Proteus Spectrum
  • Sound
    Generic Dell Speakers and Razer Kraken USB
  • Operating System
    Windows 10
https://linustechtips.com/topic/637431-6600k-overclocking-problems/
thr
1 minute ago, SpeederT12 said:
Hey guys,
throttling maybe
Dendrotoxin
CPU: i5 6600k @ 4Ghz | GPU: Zotac AMP! 1070 @ 2GHz | RAM Crucial Balistix 2x4GB | PSU EVGA G2 750w | Cooler: NZXT Kraken x61 | Case Phanteks Eclipse P400s | Motherboard Gigabyte G1 Gaming Z170 | Storage: Toshiba 3TB HDD and MyDigitalSSD M.2 256GB
Perripherals
Keyboard(s) Razer Ornata Chroma, Razer Tartarus Chroma | Mouse: Logitech G502 Spectrum | Headphone: Audio Technica M40x | Monitor HP 22CWA
Just now, VictorianReaper said:
thr
throttling maybe
57 degrees celsium
  • CPU
  • Motherboard
    Gigabyte HD3p z170
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM650x
  • Display(s)
    Dell U2414H
  • Cooling
    CM Hyper 212 EVO
  • Keyboard
    Logitech G810
  • Mouse
  • Sound
  • Operating System
    Windows 10
1 minute ago, VictorianReaper said:
thr
throttling maybe
What are your temps? EDIT: Was posted above while I was writing :)
What is your voltage?
Also, leave cache stock while you're changing the multiplier for cores. Do cache after you've done the rest.
CPU: i7 6700k (4.7 GHz) | GPU: EVGA GTX 1070 FTW (OC) | Motherboard: ASUS Sabertooth Z170 S | Cooling: Corsair H110i GTX | Storage: 250GB Samsung 850 EVO M.2 + 1TB WD Black | RAM: 16GB (2x8) Corsair Vengeance LED (White) 3000MHz | Case: Phanteks Enthoo Evolv ATX | PSU: Corsair RM850i | WiFi Card: TPLink Archer T9E | Case Fans: Noctua iPPC-2000 PWM (3x 120mm in), 2x Noctua NF-A14 PWM 140mm (radiator, painted black), Fractal Venturi HP-14 (1x 140mm out)  | OS: Windows 10 Home 64-bit
Havent touched voltage so that is stock... Also noticed that it thinks that my 1070 has 4gb of vram...
  • CPU
  • Motherboard
    Gigabyte HD3p z170
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM650x
  • Display(s)
    Dell U2414H
  • Cooling
    CM Hyper 212 EVO
  • Keyboard
    Logitech G810
  • Mouse
  • Sound
  • Operating System
    Windows 10
Mine said that too for a little bit. Check in GPU-Z.
Try increasing your voltage to 1.325 and see if it helps. That should be a safe level and should allow multiplier over 40 easily.
my 8350 does this all time and it seems to be due to the front side bus dropping below 200mhz (100 on intel).
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
ohh wait, could it be the turboboost speed im changing? And I want to use the basic tuning first before fiddling with advanced tuning with voltages and per-core multipliers
  • CPU
  • Motherboard
    Gigabyte HD3p z170
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM650x
  • Display(s)
    Dell U2414H
  • Cooling
    CM Hyper 212 EVO
  • Keyboard
    Logitech G810
  • Mouse
  • Sound
  • Operating System
    Windows 10
You could be very well increasing the turbo rather than base clock.
Hmm, which program did you use to oc? Did you use XTU?
  • CPU
  • Motherboard
    Gigabyte HD3p z170
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM650x
  • Display(s)
    Dell U2414H
  • Cooling
    CM Hyper 212 EVO
  • Keyboard
    Logitech G810
  • Mouse
  • Sound
  • Operating System
    Windows 10
Oops, sorry, you are the one with the 8350, wrong quote.
  • CPU
  • Motherboard
    Gigabyte HD3p z170
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM650x
  • Display(s)
    Dell U2414H
  • Cooling
    CM Hyper 212 EVO
  • Keyboard
    Logitech G810
  • Mouse
  • Sound
  • Operating System
    Windows 10
Alright, which program are you using to overclock? I am kinda new to overclocking (like voltages freak me out) soo yeah
  • CPU
  • Motherboard
    Gigabyte HD3p z170
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM650x
  • Display(s)
    Dell U2414H
  • Cooling
    CM Hyper 212 EVO
  • Keyboard
    Logitech G810
  • Mouse
  • Sound
  • Operating System
    Windows 10
You should only be overclocking with your bios. Use a program such as HWMonitor along with prime95 to stress test your cpu.
Use the BIOS. It's the most failsafe way - if you really mess up, you just reset it to default and voila you're fixed (most of the time).
Basically I'd recommend BIOS, but if you really want software then Intel Extreme Tuning Utility (XTU) works well.
Alright, will do, thanks!
  • CPU
  • Motherboard
    Gigabyte HD3p z170
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM650x
  • Display(s)
    Dell U2414H
  • Cooling
    CM Hyper 212 EVO
  • Keyboard
    Logitech G810
  • Mouse
  • Sound
  • Operating System
    Windows 10
Set voltage to manual mode and type in 1.325. Then increase the CPU core multiplier to 4.3 or whatever (that should work, you can raise this and/or lower voltage later).
Test using AIDA64 or Prime 95 - be careful with prime though, it can overheat too much. Have CPU-Z open to watch the clock speed/temps.
You know, that's a pretty high voltage for a hyper 212. That cooler isn't as good as people think. I wouldn't recommend going with that straight away. Rather, OP should start at something lower (say, 1.25) and work his way up.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
I didn't know that - haven't ever used one myself, just assumed it worked as well as everyone says. Good to know!
