Hello kind folks of LTT community.
First I would like to apologize for any grammar mistakes since English is far away from my mother language.
 Okay, to bussines:
I have a fairly old pc that I want to upgrade. I don't have the money to upgrade it all at once or simply build a new pc, I want to take it slow (for example: first the graphics card, then the PSU, CPU, etc..)
Could you please help me decide what to upgrade to and in what order if it's even worth upgrading it.
MY CURRENT PC SPECIFICATIONS:
MOTHERBOARD: Gigabyte Technology Co. Ltd. Z77M-D3H
CPU:  i5 3550 3.30 GHz to 3.70 GHz
GPU: Nvidia GTX 440 1023 MB
RAM: 2x4GB HyperX Savage (so 8GB total)
PSU: LC power 420 W
If you want to know anything else just say so and you'll find out.
I thank you in advance for any kind of help and/or advice :)
EDIT: I just noticed I spelled UPGRADE wrong in the title.. Sorry.
https://linustechtips.com/topic/637357-help-with-my-uprage/
I would upgrade the psu before anything, then a new gpu, and then if you are looking for something an ssd can improve overall performance.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/637357-help-with-my-uprage/#findComment-8223808
1 minute ago, Jstone said:
first off you need more ram and a better gpu that should be everything you need
8gb is fine, that psu is a fire hazard.
https://linustechtips.com/topic/637357-help-with-my-uprage/#findComment-8223814
Yeah the PSU upgrade is inavitable. Any suggestions? Do keep in mind that I'm from Europe and might not have acces to some stuff. Thank you for your help guys tho :)
https://linustechtips.com/topic/637357-help-with-my-uprage/#findComment-8223829
1st off replace the PSU, it is generic garbage. I'd replace it with an EVGA G2, B2, GS, GQ, P2, Anything from Seasonic and XFX (exlcuding the XT) Corsair RMi, RMx, HX, HXi, AX, AXi
Then replace the GPU with something like a R9 380 4GB, you could probably get a RX 480 in there if you want to though.
The CPU and RAM is fine ATM.
https://linustechtips.com/topic/637357-help-with-my-uprage/#findComment-8223834
