Hey people!
i am looking to build my first pc, and have been looking around for hardware and stuff
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Noctua NH-D9L
Motherboard: Asus MAXIMUS VIII GENE
Memory: Kingston HyperX Fury 8GB DDR4-2133 Memory
Storage: Kingston SSDNow V300 Series 240GB 2.5"
Case: Corsair Air 240
Power Supply: Corsair CXM 650W
As for the video card i was thinking about a rx480, but was considering waiting for some costum ones to come out.
my plan was to start with a single one, and then upgrade with another one for crossfire in a couple of months.
What do you think?
https://linustechtips.com/topic/636720-my-first-build/
dump that v300 for an adata sp550 or ocz trion ssds, the v300 has terrible performance for an ssd. otherwise it looks fine.
https://linustechtips.com/topic/636720-my-first-build/#findComment-8216645
Just now, Bror Emil said:
Hey people!
What do you think?
Budget and country of origin.
I will most likely not respond to you in a thread unless you quote me.
$500 PC | $800 PC | $1000 PC | $1200 PC | $1500 PC | $2000 PC | $2500 PC | $3000 PC | $4000 PC
Damnit Carl (My portable POS):
CPU: Core i7-6700HQ
Motherboard: Toshiba L55-C5392 Mobo
RAM: 8GB DDR3 (even though I have Skylake)
GPU: Intel HD Graphics 530
Case: Toshiba L55-C5392 Case
Storage: 525 GB Crucial MX300 SSD
PSU: Whatever power jack comes with it
Display: Some 1366 x 768 garbage + an OK 1080p monitor
Cooling: Not enough + an external laptop tray
Keyboard: The included one
Mouse: $4 Lenovo 3D Optical Mouse (not as bad as you (rightly) assumed)
Sound: The Skullcandy branding right under the power button should clue you in
Operating System: Windows 10 Home
PCPartPicker URL: pcpartpicker.com/i-wish-i-had-enough-money-for-a-desktop-my-laptop-is-so-sh*t-its-not-even-on-portablepicker
https://linustechtips.com/topic/636720-my-first-build/#findComment-8216653
like a OCZ Trion 150 SSD - 240GB ?
around $1000 without the video card(s). i live in denmark, so availability and pricing might be a bit different
https://linustechtips.com/topic/636720-my-first-build/#findComment-8216686
yes.
https://linustechtips.com/topic/636720-my-first-build/#findComment-8216690
