Your build looks great! I recommend a mid tower if you have some extra space on your desk. Maybe a NZXT Source 210 or Corsair 200R?
Also, I would recommend a 1440p monitor like http://www.newegg.com/Product/Product.aspx?Item=N82E16824009728&cm_re=1440p-_-24-009-728-_-Product
The power supply is a great psu, Don't worry!
Good luck!
https://linustechtips.com/topic/636228-first-build/#findComment-8211286
3 minutes ago, Poohl said:
2 * 4GB Ram would double your Ram speed. (Dual Channel)
Wouldn't effect gaming that much, only work use scenarios.
11 minutes ago, LeafyCarp said:
PCPartPicker part list: http://pcpartpicker.com/list/47R9Gf
Price breakdown by merchant: http://pcpartpicker.com/list/47R9Gf/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($199.99 @ SuperBiiz)
Motherboard: MSI B150M PRO-VDH Micro ATX LGA1151 Motherboard  ($73.99 @ SuperBiiz)
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2133 Memory  ($30.98 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($57.99 @ Newegg)
Storage: Hitachi Deskstar 2TB 3.5" 7200RPM Internal Hard Drive  ($62.80 @ Amazon)
Video Card: Gigabyte Radeon RX 480 8GB Video Card  ($239.99 @ SuperBiiz)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  ($58.99 @ SuperBiiz)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($65.99 @ SuperBiiz)
Wireless Network Adapter: TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter  ($12.11 @ Newegg)
Monitor: AOC i2267Fw 22.0" 60Hz Monitor  ($103.88 @ B&H)
Total: $906.71
Generated by PCPartPicker 2016-08-01 10:31 EDT-0400
I used the 480. You can switch that for the 1060 if you want.
https://linustechtips.com/topic/636228-first-build/#findComment-8211334
change the 600B to something like an XFX TS 550w, Seasonic S12ii or rosewill capstone G650 instead. otherwise you're fine.
https://linustechtips.com/topic/636228-first-build/#findComment-8211338
Just now, LeafyCarp said:
Sorry, I'm mildly new to computer parts. What is the B 1 series?
I definitely do not want to spend $1000, but I'm willing to dip into $900.
I plan on getting a second 8gb stick of ram when my next paycheck comes in, btw.
The model of the PSU. Not a great one at that.
Why wait:
PCPartPicker part list: http://pcpartpicker.com/list/M4pL2R
Price breakdown by merchant: http://pcpartpicker.com/list/M4pL2R/by_merchant/
Memory: GeIL EVO POTENZA 16GB (2 x 8GB) DDR4-2400 Memory  ($49.98 @ Newegg)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  ($39.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($58.99 @ SuperBiiz)
Total: $899.71
Generated by PCPartPicker 2016-08-01 10:37 EDT-0400
https://linustechtips.com/topic/636228-first-build/#findComment-8211353
